Four Eyed Forums
Go Back   Four Eyed Forums > Tech > Mods, Maintenance and Mechanicals
Notices
Reply
Thread Tools Display Modes
Old 05-09-2007, 10:40 AM   #1
Shadow 1
Shadow 1's Avatar
Send a message via Yahoo to Shadow 1
Default 91 Crown Vic 5.0L
Just a quick question guys, will a 91 crown vic 5.0 engine fit in a 85 and run well without any modifications?
__________________
-Kal
"One man can make a difference." -Wilton Knight
85 Mustang GT T-Top
THE WRAITH
RIP -Shilo B. Dec.'09
Quote:
Women are like cars, sometimes you find one you fall in love with, and sometimes you end up with a lemon.
Shadow 1 is offline   Reply With Quote
Old 05-09-2007, 10:50 AM   #2
peicaprilover
peicaprilover's Avatar
i'm sure somebody will chime in, but, i happened to have a 91 crown vic 5.0 in my building and it looks alot different than my 88 5.0, first off the plenum is facing the opposite way, and the pulleys on the front of the engine seem all different, not saying it won't work though. but there are definately some differances, also the motor mounts are completely different looking also
__________________
1988gt hiding in a 90lx
1985 capri gs 5.0-
3 88lx parts cars
89gt parts car
[U]2 95intrepid-1parts,1daily driver
www.mustangcanada.com
peicaprilover is offline   Reply With Quote
Old 05-09-2007, 11:08 AM   #3
Shadow 1
Shadow 1's Avatar
Shoot, ok. I came across one on craigslist for $200 complete and I was hopeing it would work. I don't plan on keeping the EFI so a computer wouldn't be a problem, engine configuration is. I wanted a 302 that I can just throw in there and I wouldn't have to do a lot of modifying to. Right now there is nothing, not even a tranny. So would a 302 out of a stang and not one out of a crown vic or a bronco/truck be the best solution to my problem?
__________________
-Kal
85 Mustang GT T-Top
THE WRAITH
Old 05-09-2007, 11:14 AM   #4
peicaprilover
i'm not saying that it won't work, i'm just saying that there are noticeable differances just looking at them anyways. the changes needed may be simple. but yes another mustang motor would definately be alot easier. i'm sure someone will "chime" in here shortly and give you a better answer.
__________________
1985 capri gs 5.0-
3 88lx parts cars
89gt parts car
Old 05-09-2007, 11:15 AM   #5
Shadow 1
Shadow 1's Avatar
Thanks man, I appreciate your help.
__________________
-Kal
85 Mustang GT T-Top
THE WRAITH
Old 05-09-2007, 11:45 AM   #6
854vragtop
854vragtop's Avatar
The Crown Vic longblock motors use E6 heads, cast pistons, and a milder roller cam than the HO cam. Ignition firing order is also different with this particular cam. The longblock will work, but it's not a performance engine. You can swap out the cam for an HO cam and swap the plug wire locations to have the correct firing order for the HO cam.
__________________
Stock bottom end, Comp Cams XE264HR-14, GT-40P heads w/ Alex's springs, Weiand 8124 Street Warrior
My photo website:
http://www.twilightphoto.com/
854vragtop is offline   Reply With Quote
Old 05-09-2007, 02:02 PM   #7
MIKE82
MIKE82's Avatar
since you are not going efi. all you should have to do is swap your carb and intake setup onto it. swap on some mustang motor mounts and that really should be it. now this isn't taking into consideration the flywheel, flexplate, bell housing etc. however a 302 is a 302. what you can do to one, you can do to another. this engine, as stated before isn't the highest performing 302 but it can be made to work. a mustang 302 would be an easier, better performing path to v-8 fun though.
__________________
79 302 cobra project
MIKE82 is offline   Reply With Quote
Old 05-09-2007, 02:08 PM   #8
Shadow 1
Shadow 1's Avatar
Quote:
I think you guys have a point. I just may look for a stang motor, I might even be able to find the matching t-5 tranny. The only thing is around here, from my experience, it's hard to find a stang motor, especially if you are on a budget. crown vic's and bronco/f-150 motors are easier and cheaper to find. I just don't want the headache of trying to make it work where it wasn't intended to be. There again having a HO wouldn't be a bad thing either
__________________
-Kal
85 Mustang GT T-Top
THE WRAITH
Old 05-09-2007, 02:10 PM   #9
Shadow 1
Shadow 1's Avatar
I just came across a 88 HO engine out of a stang complete with the puter out of a stang for $450 OBO in washington. Is that a good thing? I also just came across one for $200 out of a 94-95 with the 5.0 .
__________________
-Kal
85 Mustang GT T-Top
THE WRAITH
Old 05-09-2007, 08:53 PM   #10
854vragtop
854vragtop's Avatar
Don't forget about the early V8 Explorer motors with the GT-40 heads. Can't remember when they first started putting the 5.0 in the Explorers, but up to 1996 1/2, they had the GT-40 iron heads. After that, Ford installed the GT-40P heads, which would require different headers and ditching your EGR system and air injection at the back of the heads.
__________________
My photo website:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
