Results 1 to 8 of 8
Thread: Door Tag Decode
    Default Door Tag Decode
    I tried the link to decode the door tag but it says bad VIN just like it did yesterday for the buck tag. I try to be self sufficient.
    86 Mustang GT VIN
    1FABP27M7GF228929
    Most of it is straight forward. My guesses below. Probably the only important one is the radio.
    Ext Paint 9L, Oxford White
    DSO 72, San Jose
    Body 66B, Convertible
    V/R ?
    Int Trim GW, gray and white (seats and door panels)
    Tape 1, Gray hood decal
    R 6, Radio type?
    Ax M, ?
    TR 2BBTT, ?
    Thanks for any info.
    1FABP27M7GF228929 is an invalid VIN (the check digit "7" is not valid for the other 16 characters). The correct check digit for 1FABP27MxGF228929 is "6". The correct VIN would be 1FABP27M6GF228929.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Thanks for the info. Unfortunately, what I posted is exactly what is on the door tag. There is no "6". I will check the windshield. I would post a photo but photos have not worked here for years.
    Windshield tag vin is the same as the door.
    VIN confirmed with CA DMV.
    email: svo413 at aol dot com
    Sent you an email from foxchassis at att dot net
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    You posted last six of the VIN as 228929. The last six of the VIN in your pics is 228292.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Ok, my error. It did pop up on my computer but then advanced to a search screen. It seemed to work fine on my iPad. Thank you.
    Any idea if #6 radio is manual or ETR?
    Code 6 radio is the fancy one ... AM/FM electronic search stereo radio with cassette tape player
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Date - 04/86 = April 1986 build
    GVWR - 4150 lb/1882 kg = gross vehicle weight rating
    Front GAWR - 2206 lb/1000 kg = front gross axle weight rating
    Rear GAWR - 1993 lb/904 kg = rear gross axle weight rating
    F0053 = 0053 lbs front accessory reserve load
    R0031 = 0031 lbs rear accessory reserve load
    Exterior Paint Colors - 9L = Oxford White
    DSO - 72 = San Jose district sales office
    Body - 66B = Mustang 2-door sedan (coupe)/2-door convertible
    VR - W = White convertible top
    Int Trim - GW = leather Articulated Sport seating, low-back front buckets (G), Oxford White and Charcoal interior trim color (W)
    Tape - 1 = Dark Charcoal hood stripe, Medium Charcoal Mustang GT decal on trunk
    R - 6 = electronic AM/FM search stereo radio with cassette tape player
    Ax - M = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = manual Borg Warner transmission (T5 5-speed overdrive)
    BB = front springs
    TT = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
