Results 1 to 5 of 5
    Default Swapping a non AC heater box in my 86?
    Odd question....but....I am getting ready to start a heater core replacement. My 86 very iis a factory ac car, and I am not looking forward to it. Question is....can I swap the heater boxes out and keep the ac dash vents? Just pull out the old ac box, and put in a non AC heater box?
    Not sure if it's that easy, as the firewall is different between the two. But someone with more experience will know for sure.
    The firewall is the same for 1986, but the hole location is different between the two boxes. The A/C box uses the large opening for the Evaporator lines and the heater core hoses. The heater only box doesn't use the large opening and the heater core lines are in a slightly different location and go through individual holes in the firewall from what I recall. Can it be done, Yes! You will have to fabricate a cover for the current large opening and possibly the mounting holes to make the switch.
    I am sure you can modify the box to work with the A/C vents, but again that will take some fabrication and modification. Again doable, but how much fabrication I can not say as I have never attempted. In my experience a good quality heater core, using the OEM style restrictor in the heater hose, quality anti-freeze and correct mixture will allow for a long heater core life and most likely never have to replace it again. Much easier and quicker option than all the changes needed to go from A/C box to heater only. Just my .02, your opinion may vary. Good Luck!
    Aug 2003
    Villa Park, IL
    And the non A/C boxes are hard to find. If you have one already, that's half the battle, but like Trey said...
    I believe what Trey was saying, just use the AC version of the heater box. Put a new heater core in and you should be good for a while. A big part of the difficulty is working with the AC lines intact.during the heater core replacement. I would put a black foam pad over the ac line holes from the inside.
