Tech Article: '83 - '86 CFI/EFI Fuel Sender Repair Print
Wednesday, 16 March 2011 11:22
Can't find that replacement '83 - '86 CFI/EFI Fuel Sender? Tried to use the 87-93 sender only to find out your fuel gauge doesn't read correctly now? That is because there isn't an aftermarket sender available for the 83-86's and the resistance value on the 87-93's is incorrect for use with the 83-86 CFI/EFI cars.
Thanks to JACook we now have a repair tech article available for you to fix your old one with a sender that is readily available at the parts store!
Link : '83 - '86 CFI/EFI Fuel Sender Repair
Thanks Jeff! Great work!
Fuel Senders
